accidently ran car with maf disconnected then reconnected it but got a code
Old Jun 23, 2001 | 05:19 PM
Stormshadow GTA's Avatar
would that cause a code the next day the ses light didn't come on so does that mean the code is gone.
1987 Trans AM GTA
305 5SPD
Hypertech airfoil
gutted maf
kn filter
High Flow Cat,
3"Walker pipe
Dynomax Super turbo Muffler
TB Coolant bypass
Old Jun 23, 2001 | 06:17 PM
rondubbs's Avatar
just disconnect your battery for 30 seconds and that'l clear the codes... if you get an ses light after doing this that means you really do have a code...
Old Jun 23, 2001 | 06:28 PM
Vader's Avatar
SSGTA,
The MAF Diagnostic Trouble Code should have been a 34, and possibly a 36. The ECM will retain error codes (DTCs) for the last 50 engine starts. It will probably remain in memory for about two weeks. You can wait or you can clear the code (and all ECM RAM) by disconnecting the EM powewr for about five minutes. That should be long enough to clean the battery cables/terminals. Once you restart, the engine will warm up and the ECM will begin writing new data tables based on your inputs and driving conditions. Drive the car normally for about twenty minutes under varying conditions from idle to crusing speed to "reteach" the ECM. You don't have to drive the car for twenty minutes, but the next time you operate the car the data table will continue to be loaded with the new data.
If you ever make any significant changes or modifications, it's a good idea to reinitialize the ECM in this manner to keep the best fuel/spark curves for your configuration.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 23, 2001 | 09:15 PM
Thanks guys,
Vader you got a whole encyclopedia of info
1987 Trans AM GTA
305 5SPD
Hypertech airfoil
gutted maf
kn filter
High Flow Cat,
3"Walker pipe
TB Coolant bypass
specialized
Jun 18, 2022 09:26 AM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mizz0313
Aug 12, 2015 06:45 AM
