name that connector
Old Jun 19, 2001 | 08:18 PM
rockind78's Avatar
name that connector
OK. I have the factory service manual for the donor car, but I have a TPI harness from a '85 firebird. I have a connector that has seven wires going to it: two dark orange, one light orange, one red, one blue, one black and white, and one black with tan. It is in the same vicinity as the ECM connectors and IP harness connector. I know the red and the blue wires are from the MAF, leading me to beleive( well this and the manual...seemingly) this is the burn off relay, but apparently it isn't because GM keeps giving me something that looks like the fuel pump relay when I order the part. I know one of you has to have an '85 TPI out there....please help!!! Thank you.
Old Jun 19, 2001 | 08:25 PM
Guest
Guest
Posts: n/a
85 has a burnoff module, thats what the connector you have is for. I'd recommend rewiring or whatever to get around that, unless you are using an 85 ecm... in which case you might be better off getting a different ecm and wiring anyway.
Old Jun 20, 2001 | 12:04 AM
rockind78's Avatar
OK. call me crazy here, but I don't think this connector goes to a burnoff box. The dealership told me there were two vins that year and that I might not have burnoff module. If you look at this picture:
http://www.ece.udel.edu/~davis/z28/e...0FTMmodule.jpg
you will find that this is the connector for the burnoff module...correct? My connection doesn't look anything like this. It looks like the connector on the far left of this picture:
[http://www.ece.udel.edu/~davis/z28/ecm_swap/ecms-photos1/ecmharnessconnectors.jpg
This is the connector I am wondering about.
[This message has been edited by rockind78 (edited June 20, 2001).]
Old Jun 20, 2001 | 06:25 PM
Lov2xlr8's Avatar
if its wo connectors like recyangle, it may plug into the inside dash harness, it should have 8 slots on on slide and seven on the other. 85 was its own mess, every other T/Pi is differentr from it
Old Jun 20, 2001 | 06:58 PM
rockind78's Avatar
What I meant, was that the connector I am asking about it at the far left of this picture:
http://www.ece.udel.edu/~davis/z28/e...connectors.jpg
For some reason, the message editing doesn't want to be working.
Old Jun 21, 2001 | 01:09 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
Yep, Max is right... that's the burnoff module connector.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, Rapidfire #2 @ .055", MSD 6AL, 1.6:1 Roller tipped rockers, Homemade AFPR, K&N cone, no airbox, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Descreened MAF, Syclone Fuel Pump, JET Airfoil, Mobil 1 synth in all but transmission.
http://www.geocities.com/transam85tpi/
Old Jun 23, 2001 | 10:30 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
That connector, the far left in the pic, is
the dashboard harness connector, forgive me if this is not the correct name, but that is the best way I can describe it. There should be a corrosponding connector under the dash near the ecm.
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
