no start over fueling
i got a 87 camaro wit a 350 tpi, it will not start, i got it to run a couple of times and i had raw fuel flying out the exhaust. also if i crank it, u can smell fuel around the intake, and smell it in the oil. yea its gettin over fueled real bad..... i changed the maf, and the comupter. fuel pressure regualtor is good. i dont know wat it could be. j/w if anyone had this problem, and if anyone can give me any suggestions on what could be happening....
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: no start over fueling
I had that exact same problem back in 1996. I replaced the ECU with a new one but still had the flooding of fuel. It turns out the PROM was shorting out the ECU. Luckily, I was able to get the ECU under warranty and replaced the PROM with a new one. That did the trick. Did you replace the PROM along with the computer? You might short the new one if you just re-installed the old PROM.
yea i did put the old prom back..... ****. also my ses lite doesnt come on........ thats y i replaced the ecm. its no problem to replace it i just gotta get a new prom. i work at a napa, so gettin parts replaced aint a problem.
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
