how to install roller camshaft?
Old Jun 27, 2001 | 09:46 PM
james_fearn's Avatar
Do I need to remove the spider and all the roller lifters? or is there an easier way.
Since it is a roller camshaft, is using engine oil good enough lube or do I still need regular camshaft break-in lube? The engine will go in in 1~2 weeks.
How exactly does that spider thing work? It looks like it just holds down the <><> bracket but also allows for it to be bumped once in a while. It also looks pretty week.
James
Old Jun 28, 2001 | 12:19 AM
Guest
Guest
Posts: n/a
Yes, you have to take out the spider and all the link bars and lifters. The spider isnt really weak, it just holds the bars down against the lifter valley, not much of a job.
Oil will probably run off in a couple weeks time, so if you arent going to prime the engine first before you fire it up (which I would suggest) then you may want to use a little lube on the cam.
junkcltr
Aug 2, 2019 11:12 PM
Caspar
Jun 19, 2016 11:19 PM
red90IROCls1
Aug 25, 2015 06:56 AM
Jake_92RS
Aug 17, 2015 09:42 AM
