TPI Intake bolt torque pattern?
Old Jan 16, 2008 | 04:13 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
just need the torque down pattern for the tpi intake..thanks
Old Jan 16, 2008 | 04:26 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: TPI Intake bolt torque pattern?
For the base or runners?
For the base, nearly all patterns start at the center most bolt, and then move outward, alternating sides. This makes for the most evenly distributed clamping force.
Old Jan 16, 2008 | 05:10 PM
Car: 89 Formula 350
yes for the base. I was thinking the same pattern u stated. My chiltons manual was showing the passenger side then moving to the drives side which seemed strange
Old Jan 16, 2008 | 05:26 PM
Its not sensitive enough to really matter which side you start on. As long as you evenly torque the bolts in a alternating sequence you'll be fine.
Much like torqing lug nuts in a star pattern. its so the wheel seats correctly.
Old Jan 16, 2008 | 05:28 PM
Car: 89 Formula 350
8. 7. 9. 10. 11. 12.
front engine TPI Intake
2. 1. 3. 4. 5. 6.
I guess I'll go with the way it says to torque the TPI Intake but the TBI way looks better and i'll only be torqueing to 18lbs. because its going to aluminum heads not iron
5. 6. 4. 1. 7. 8.
front engine TBI Intake
9. 10. 3. 2. 11. 12.
Old Jan 16, 2008 | 05:56 PM
deadtrend1's Avatar
i wouldn't do the one side, then other side way. I've always done the center, and worked my way out in a circular motion and haven't had a problem.
oh, And on my LT1 (alum. heads) they still called for 30 ft/lbs. tq spec
Old Jan 16, 2008 | 09:15 PM
Car: 89 Formula 350
Brodix and AFR say to go with 18lbs
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
9192camaro
16
Feb 3, 2019 12:21 AM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
