injector ohm results
Old Jan 16, 2008 | 07:38 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
I was just curious as to if there should be any difference in ohm results between the ford svo's and the stock bosch style. I have a set of 24lb'ers that are ohm'n 14.8 for all 8 injectors and my 19lb stockers are ohm'n about 16.8 -> 17.2
Are the svo's toast?
Old Jan 16, 2008 | 08:29 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: injector ohm results
Nope, those specs are just right. Anything less than 12 ohms would be suspect. Check them again when they're hot from running on the engine, if you can. Sometimes they test ok when cold but fail when they're hot.
92-Formula
Dec 12, 2015 10:34 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
