Ignition Advance- Old Large Cap HEI
Old Jan 17, 2008 | 03:33 PM
jimchristiansen's Avatar
Car: Jeeps
Engine: 1970 4 bolt 350, 19000 miles & TPI
Transmission: Tubo 350
Axle/Gears: 4:11
I'm to the point of needing to hook up my vac advance to the manifold somewhere and suddenly find myself asking "Is there even a ported vac source on a tpi system?"
Can I get my old vac advance plumbed in?
Thanks, Jim
Old Jan 17, 2008 | 03:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Ignition Advance- Old Large Cap HEI
No, there's no ported vacuum on TPI. Why would you want to run vacuum advance on a TPI system in the first place?
Old Jan 18, 2008 | 10:02 AM
Car: Jeeps
Axle/Gears: 4:11
I didn't give enough info. Sorry. I have an old 3/4 truck 4 bolt and a 92 vette tpi manifold set... Also, 4 months ago I bought one of those sexy eBay large capped mech/vac advance clear capped high output distributors. I was hoping to be able to use it without driving the ignition by the megasquirt.
I do have a small used computer controlled hei that I thought I'd install after running the engine fuel only MS2 for a while.
Old Jan 18, 2008 | 11:19 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The old distributor probably isn't going to be able to send the right signals to the megasquirt anyway.
Old Jan 18, 2008 | 11:32 AM
Car: Jeeps
Axle/Gears: 4:11
Yeah... May as well ditch the large clear cap for this setup.
I'm glad I didn't use the small capped hei as mallet while it was on the bench the last few months!
Thanks, Jim
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
