Anyone?
Old Jun 26, 2001 | 09:14 PM
Flesh's Avatar
Anyone?
Help.
Old Jun 26, 2001 | 11:10 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Just connect the red wire to where it goes.
Old Jun 27, 2001 | 01:11 PM
Zoxo's Avatar
It usually plugs into the blinker fluid reservor above the muffler bearings, and to the left of the 750cfm water pump.
Old Jun 29, 2001 | 03:49 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
wrong wire that one goes to the flux capacitor try putting fresh air in your tires the stuff in there now must be stale.
Old Jun 29, 2001 | 03:50 PM
PETE's Avatar
Car: 1989 TTA #1240
Transmission: 2004r
also check your high beam fluid it might be low
Old Jun 29, 2001 | 04:24 PM
whiterocz's Avatar
im assumming your having problems after installing your air filter eliminator kit. all you need to do is get the exaust manifold eliminator kit and you will be up and going in no time.
(btw, these kits arent cheap. they run from 250-350 dollars)
[This message has been edited by whiterocz (edited June 29, 2001).]
Old Jul 2, 2001 | 09:37 AM
Velocity's Avatar
now to install all of this, your going to need a left handed gonad wrench. You ahould be able to pick one up at your local parts store...
Old Jul 2, 2001 | 12:51 PM
IROC-Z_85's Avatar
WARNING: Do not start this project unless you are fully prepaired and capable of replacing all of your piston return springs.
Just a precautionary notice.
1985 IROC-Z, nuff said :P
