TPS voltage and AIC valve...wtf?!
Okay...https://www.thirdgen.org/newdesign/tech/tpimod1.shtml says it will define what those 2 are but the links are bad...can i get some help here?
What are those 2 things?
1990 G92 5spd LB9 - 3.42 80,000 miles
Accel Ignition/Wires (8.8mm), Advanced Timing, TB Bypass, Ported and Gasket Matched Plenum, Synthetic Motor Oil, 160 Thermo, TPIS Airfoil, K&N Air Filters, Centerforce I Pressure Plate and Clutch, Edelbrock TES Headers, Dual Cats, Edelbrock RPM Series Catback, Homemade Ram Air, Bosch +4 Platinum Plugs
14.4 @ 94mph w/2.0622 60ft (w/o headers and catback)
14.426 @ 96.19mph w/2.167 60ft(w/headers and catback)
<font face="Verdana, Arial" size="2">Originally posted by 90Iroc-Zee:
</font>
</font>
https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
Hey Webmaster: The problem with the links are as follows ->On this page https://www.thirdgen.org/newdesign/tech/tpimod1.shtml the blue links shown here point to --
( "TPS Voltage- It "must" be right on, or your engine will not be running at its peak potential. It must be read with a digital VOM and set accordingly. <font color="0000DD">This is outlined here." </font>
"IAC Valve- This determines your engines idle speed, and it also must be set correctly or you will be experiencing idling and low speed drivability problems. <font color="0000DD">This is outlined here."</font> )
https://www.thirdgen.org/newdesign/tech/tpimod2.html is wrong and should read https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
This is a <font color="red">S</font>imple fix guys.
89 IROC-Z 5.7L 2.77 GEARS
130,000 MILES
ALL FREE MODS
K&Ns FILTERS
FLOWMASTER MUFFLER
PERFORMANCE RESOURCE CHIP
Best 1/4 E.T. 14.37 @ 95 MPH
Best 1/8 E.T. 9.22 @ 76 MPH
Best 60ft. 2.07
I put the AFPR on, ported the plenum. This run was made last Friday. (6/29/01)
New Best 1/4 E.T. 14.09 @ 97.2 MPH
New Best 1/8 E.T. 9.09 @ 77.4 MPH
New Best 60ft. 2.03
[This message has been edited by whiteroc (edited July 02, 2001).]
thx bunches...now i just have to learn how to tune this stuff = D
BumpaD82
Feb 26, 2016 02:57 PM
HoosierinWA
Oct 7, 2015 10:15 AM
MikkoV
Sep 9, 2015 04:25 PM
