Old Jul 2, 2001 | 11:58 AM
IROC-Z_85's Avatar
1.6 305
Cam's done, now im thinking of getting some 1.6 roller tip rockers. All I want to know is if anybody out there with a 305 has done this with enough clearance in the heads.
1985 IROC-Z, nuff said :P
Old Jul 2, 2001 | 05:09 PM
Ron Mullins's Avatar
I have some on an 86 305 with no problems.
Old Jul 2, 2001 | 05:11 PM
IROC-Z_85's Avatar
Shweet, steal?
Notice any difference? Word is there isn't much.
Old Jul 2, 2001 | 05:15 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
If you already have an aftermarket cam you will see proably nothing for gains on a stock headed motor. Stock heads are way done flowing by .4-.45" lift so the extra from 1.6s won't do much for you, and the roller tips friction losses aren't worth the $$$ unless you have money to blow and everything else is done.
Old Jul 2, 2001 | 05:18 PM
IROC-Z_85's Avatar
Well spose I better move on to headers then..
But my lift on the cam is in the .44 range, not even at .45 yet...
I had to be carefull with the cam, and im glad i was after what i found in my engine when i tore it apart...
Old Jul 3, 2001 | 01:28 AM
SCFORMULA1's Avatar
i just put in a LT4 hot cam with the 1.6rr in my 305 TPI, no problem with the it hitting the valve covers.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
Stryker412
Sep 7, 2015 09:11 AM
willyjoejr
Sep 3, 2015 09:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
