Pics or Links on LT1 Heads on 1st gen block
Old Jan 18, 2008 | 01:03 PM
ericgzhc4t's Avatar
Car: 1986 Transam/1996 Trans AM
Engine: 5.7 LT1 .030 over
Transmission: Borg-Warner T-56 6 speed
Just wanted to know if anyoine had pics or links of where to weld up the LT1 heads to make them fit. Ive found lot of links of retrofitting the intake, I already have the intake, just need the how to on the head part...
Thanks,
Airick
Old Jan 18, 2008 | 01:23 PM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
Re: Pics or Links on LT1 Heads on 1st gen block
Not sure that would work due to the reverse cooling of those heads. I may be wrong. Good luck
Old Jan 18, 2008 | 08:31 PM
vwdave's Avatar
Look at the sticky at the top perhaps?
https://www.thirdgen.org/forums/tpi/...eads-gen1.html
Old Jan 19, 2008 | 02:26 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
yes, that link is a very good write-up. it is the one i am using for my swap.
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
