hey okfoz...
Old Jul 3, 2001 | 11:00 AM
whiterocz's Avatar
hey okfoz...
i noticed u had the baer brakes, how do you like them?
Old Jul 3, 2001 | 12:25 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Love 'em. Installation was Very easy and they gave me everything I needed, except a few zip ties.
If you have an 89+ car with 4 wheel disks you should not need the rears, 82-88 had the small rear disks.
Doing the rear brakes was a chore because you have to pull the axel shafts. (gets messy) I installed mine when I went to TPI, had to drop the rear axel, anyway, made it really convienent.
Baer will send you some templates to check and see what brakes you can use. I wanted to use the 13" on the front, but because I had the 16" Stock rims, I needed about another 1/4" to make them fit.
John
87 Formula Yellow/Black
Engine & Transmission
.040 over 5.0 converted to TPI, 9.5:1 Compression, SLP Cam Dur 206/212, Lift 480/487, Cent Line 112, SLP headers, SLP cat-back exhaust, K&N Airfilter, Modified Stock cold air intake, Ported & polished Stock TPI intake, Holley Adjustable Fuel Press regulator, AC Rapidfire Spark Plugs.
Gil Younger (no yo-yo) Shift Kit, Aluminum Driveshaft, 3.73 Posi gear
Suspension & Brakes:
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Hotchkis strut tower brace, South side machine frame connectors, Custom reinforced control arms and pan hard bar.
Interior:
Custom Leather interior, CUSTOM Yellow Gauge Faces, Kenwood Receiver, Pioneer Speakers, Kicker Substations, Kenwood 10 Disk Changer, Pioneer Amp.
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
[This message has been edited by okfoz (edited July 03, 2001).]
Old Jul 3, 2001 | 03:37 PM
whiterocz's Avatar
what about performance? how do you rate them against stock?
Old Jul 3, 2001 | 03:54 PM
okfoz's Avatar
I was scared to drive my car BEFORE I changed over to the BAER brakes if that helps. I can really STOP now.
Way I had it figured, stopping is more important than going.
Loudnproud86
Jul 14, 2016 12:59 AM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
Zane Story
Oct 8, 2015 12:40 PM
chuck13
Interior Parts Wanted
Sep 22, 2015 11:19 AM
Keiffer76
Sep 9, 2015 08:52 PM
