Need help removing smog pump and AIR valve?
Old Jul 5, 2001 | 07:38 PM
Jas89TTA's Avatar
I'm removing my smog pump and AIR valve off my 87 Trans Am, but how do I get the AIR tubes off? They are bolted to the heads on the back of my engine and there a PITA to reach. Can I just leave them on the car and just remove the pump and AIR valve and cap-off the AIR tubes on my headers? I figured I'd disconnect the tube going to the CAT and crimp the small tube on the CAT till I get a chance to remove it. Is there anyhing elese I would need to disconnect? BTW: It's on a V-belt system.
350 TPI, 5-spd, 3.73 gears, Posi-Rear, LT4 Hotcam, 1.6 Roller Tip Rockers, Accel Intake, Ported SLP Runners, Ported Stock Plenum, Ported Cast Iron L98 Heads, Coated Hooker Headers, 52mm Edelbrock Throttle Body, 24# SVO Injectors, SLP Cold Air Intake, Holley AFPR, LS1 Aluminum Driveshaft, Flowmaster Exhaust, Taylor Wires, MSD Coil,
Engine pic at http://albums.photopoint.com/j/Album...410&a=13413975
Old Jul 5, 2001 | 08:18 PM
Guest
Guest
Posts: n/a
You can just leave that on there, thats what I did... too much of a PITA to get off, and its not really in the way.
You dont have to crimp the tube from the cat if you cap it off.
Old Jul 5, 2001 | 09:00 PM
Jas89TTA's Avatar
Is there anything else I need to do before I start it back up? Anyone know What the cap size I'll need to get? I have the valves off already just wonder what size so I won't be in the hardware store forever finding the size needed. Thanks, Jason
italiano67
Dec 11, 2016 09:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
NBrehm
Aug 25, 2015 11:49 PM
jackhammer
Aug 15, 2015 10:04 PM
3rdgenparts
Aug 8, 2015 07:09 PM
