maf to speed density
Old Jan 25, 2008 | 08:23 PM
tpicamarokid85's Avatar
Car: 1985 Z28 (project) drive 2006 F-150
Engine: to be deturmined
Transmission: to be powerglide
Axle/Gears: to be 9".. spool.. possibly 5.14:1
hey guys... justfinished searching the speed density conversion and didnt get a whole lot of info... what all is involed... what are the pros/cons... costs...difficulty of projects...hope to get a lot of posts for this topic... maybe could be a sticky?
Old Jan 25, 2008 | 08:28 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: maf to speed density
The reason I did it back when I had a stock ecm was so I could tune after where the mass air flow would have max'ed out its reading.
Difficulty? I had used my stock maf harness and repinned it to my new SD plug for the ecm. and used the maf wires re-wired to my map sensor.
Old Jan 25, 2008 | 09:06 PM
Adrians91Z28's Avatar
Car: 91 Camaro Z28 Convt.
Engine: 305 TPI (built)
Transmission: 5 spd
Axle/Gears: 3.08 posi
to what i understand .. you just get rid of the mass air flow sensor ..
and you allready got a map sensor .. if not its easy enough to hook it up .. just a vacuum line ..
and then re-pin the wires for a SD ecu .. like the 730'
hope that helps ..
ive never done it .. but then again i got a 91 z28 thats allready sd ..
Old Jan 27, 2008 | 01:56 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
There's already a very good tech article. No need for a sticky.
Old Jan 27, 2008 | 08:04 AM
Transmission: 5 spd
BumpaD82
Feb 26, 2016 02:57 PM
Nick McCardle
Sep 10, 2015 08:36 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
