smaller rims
Old Jul 10, 2001 | 05:12 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
smaller rims
when at the track has anyone ever used a 14 inch rim and tire in order to get the affect of a larger gear ratio?without having to swap my gears again would this be an option?does anyone know the equations determining this like going from a 26in. tire to a 24 in. tire would make 3.23's act like 3.55's etc.
87 trans am 350 L98 aluminum heads,LT4 hot cam,slp runners,1 5/8 headers,y-pipe,edelbrock base,hi flo cat,air foil,afpr,ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ads strip chip,relocated iat sensor,tb bypass,hollowed maf,a/c delete(whole lotta room in there now)
14.10@97mph w/2.01 60'
siamesing the slp's and my fastchip eprom is on it's way
Old Jul 10, 2001 | 07:44 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
it may act like a lower gear ratio but it will give you more rwhp. a guy in my car club (2000 z-28) dynoed with his stock 16in rims and had 300 someting hp and then put the stock 17in ss rims and lost 10 hp. since torque is force times the lever arm there is a bigger lever arm with the larger rims plus the weight is more towards the end making it harder to rotate. it can help you if you can make it stick.
its also why cars with less hp get slower trap speds when they put slicks on because they can't turn the big slicks at the end of the 1/4 mile
Andrew
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
bschmale66853
Sep 30, 2015 08:11 PM
