bolt size question...
Old Feb 1, 2008 | 03:37 PM
thedoctorisin's Avatar
Car: 79' LT1 olds cutlass/ 87' IROC
ive got an 89 tpi and i was just curious what the size of large bolt holding the harmonic balancer was and whether it would be strong enough to use to manually turn the crank?
Old Feb 1, 2008 | 03:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: bolt size question...
Turning the crank by the balancer bolt isn't recommended, it's easy to strip the threads in the crank snout.
Old Feb 1, 2008 | 05:27 PM
i was afraid of that and thanks for the confirmation, but my real problem i posted in general tech. under, "can my engine be saved" but im under the influence that my crank is siezed and i wanted to try and turn the motor with a breaker bar... being thats a bad idea, is an official way of turning the crank without the starter (because my brand new one wont) and without one of the flywheel wrenches(because i dont have one)?
im just hoping i could give it a try and fix my ignorant mistakes without having to take out the motor and trans.
Old Feb 1, 2008 | 06:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The tools you need aren't expensive, any of these would work, with varying degrees of effort.
http://store.summitracing.com/partde...5&autoview=sku
http://store.summitracing.com/partde...4&autoview=sku
http://store.summitracing.com/partde...1&autoview=sku
If you can't turn it by hand there's no work to be saved, it has to come out.
Old Feb 1, 2008 | 08:50 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Also, if it is seized..... be prepared to pull the tranny as well, as you probably wont be able to get to all of the torque converter bolts. It "is" possible to pull the engine, and the torque converter without the trans, but, it tends to trash seals, and other expensive items as well. Best just to pull the trans with the motor, and then, when you have it out on the floor, unbolt the trans, and pull it straight back, so you can get the torque converter off of the flexplate.
Old Feb 1, 2008 | 10:10 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I think that the crank bolt is an M11x1.5, but it has been awhile since I had measured this bolt.
In order to set my lifter preload, I have always turned the crank by the crank bolt.
Old Feb 2, 2008 | 10:24 AM
Vader's Avatar
The stock balancer bolt is 7/16-20 in a SBC. Use a strap wrench (marginally successful), a crank snout socket with a new Woodruff key, or a flywheel tool to try to turn the engine.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
gixxer92
Sep 1, 2015 04:32 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
knight72
Aug 10, 2015 09:32 PM
