Miniram II 383
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Miniram II 383
I was just at a friends house last night and he had a TPIS catalog. I noticed the MINIRAM II setup.
I was wondering, I am considering the folowing, anyone else out there have this setup?
383ci
MINIRAM II
10:1 compression
96-98 350 Vortech Heads
Comp Cams: 220/230 duration @ .050" and a 500/510 lift 112 L/C
87 Formula Yellow/Black
Engine & Transmission
.040 over 5.0 converted to TPI, 9.5:1 Compression, SLP Cam Dur 206/212, Lift 480/487, Cent Line 112, SLP headers, SLP cat-back exhaust, K&N Airfilter, Modified Stock cold air intake, Ported & polished Stock TPI intake, Holley Adjustable Fuel Press regulator, AC Rapidfire Spark Plugs.
Gil Younger (no yo-yo) Shift Kit, Aluminum Driveshaft, 3.73 Posi gear
Suspension & Brakes:
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Hotchkis strut tower brace, South side machine frame connectors, Custom reinforced control arms and pan hard bar.
Interior:
Custom Leather interior, CUSTOM Yellow Gauge Faces, Kenwood Receiver, Pioneer Speakers, Kicker Substations, Kenwood 10 Disk Changer, Pioneer Amp.
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
383ci
MINIRAM II
10:1 compression
Interior:
83 Camaro (Parts)
83 T/A (parts)
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
what you are speaking of is the miniram 3 it just came out and fits vortec style heads it's pricy but such is life i wouldn't bother wasting my time on the vortec heads they wont flow enough to feed a healthy 383 (bigger valves are not an option on them without cutting the guides,by the time your done porting polishing and putting bigger valves in the fastburns will be cheaper)motor go with the fastburn heads match it to the lt4 hot cam it'll scream it's head off...
87 trans am 350 L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ads strip chip,relocated iat sensor,tb bypass,hollowed maf,a/c delete(whole lotta room in there now)
14.10@97mph w/2.01 60'
slp catback tomorrow(7/13)ed wright's fastchip saturday!!!!
I have read alot of posts referring to "matching" parts to your engine. HOW would you match the fastburn heads to the cam???
John
[This message has been edited by okfoz (edited July 16, 2001).]
John
You are basically matching the power range for each given part.
Lke a tourqer cam with a miniram = stupid
If you've got some high flow heads it only makes sense to get a cam that pulls well at high rpms.
1985 IROC-Z, nuff said :P
LT1Formula
Oct 8, 2015 08:34 PM
