IAC Removal
Old Jul 13, 2001 | 11:27 AM
Justin Moore's Avatar
Car: 1986 Z28
IAC Removal
How do I remove the IAC from the intake?
Old Jul 13, 2001 | 11:30 AM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
Disconnect plug.
Unscrew.
Old Jul 13, 2001 | 12:06 PM
Car: 1986 Z28
How do you unscrew it though? There doesn't seem to be enough room to put on a wrench and turn it.
Old Jul 13, 2001 | 01:01 PM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
<font face="Verdana, Arial" size="2">Originally posted by Justin Moore:
How do you unscrew it though? There doesn't seem to be enough room to put on a wrench and turn it.</font>
Unbolt throttlebody from plenum, then use unbolt IAC from TB....
ZaphodB a.k.a Carl Andersson - zaphodb@faxancruisers.org
'89 Camaro IROC-Z 5.7L TPI - Mods under construction :-)
Custom ARAP Chip Under Development/180 t-stat, Edelbrock TES Headers,
SLP Airfoil, K&N Filters, Accel 8mm wires, Relocated MAT, AFPR @ 45 PSI
Old Jul 16, 2001 | 12:15 PM
Steve89GTA's Avatar
Don't unbolt the TB...just use an adjustable wrench.
Old Jul 16, 2001 | 01:31 PM
MikeS's Avatar
If you move some things out of the way, an appropriately sized socket slides right on. Can't remember the size right now though.
Ok, I'm home now and checked it out. 1 1/4" socket. You have to move that tube out of the way first (the one that runs from the front to the back of the engine along the top of the passenger side valve cover).
[This message has been edited by MikeS (edited July 16, 2001).]
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jk_Under
Sep 8, 2015 08:13 AM
greenyone
Sep 2, 2015 03:39 PM
