Performance TPI 350 bottom end?
Old Jul 16, 2001 | 02:35 PM
IROC-Z_85's Avatar
first off i need to make up my mind, 350 or 383...
Its going to be a daily driver so lets assume 350. Now since TPI doesn't rev for ****, is my money better spent on the upper end? I mean if im not reving like a carbed engine do i need a bullet proof bottom end?
10:1 compression, siameesed runners, ported plenum, bigger TB, and edlebrock base with SD headers etc should I make over 350 hp?
1985 IROC-Z, nuff said :P
[This message has been edited by IROC-Z_85 (edited July 16, 2001).]
Old Jul 16, 2001 | 02:36 PM
IROC-Z_85's Avatar
Oh yea..
Siameese base to match the runners
Old Jul 16, 2001 | 09:03 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
BULL S.H.I.T. look at my sig my engine gave me crap as far as hp in the upper rpm until today it was all in the chip i've been using crap proms for 2 years i feel i got it nailed with an ed wright chip my crate motor's maximum speed is 5800rpm's it never used to pull past 4800 with power now this thing runs strong right through that till 5800 andd it seems there's more but i don't want to push the stock springs,lifters,andd pushrods yet once i siamese the slp runners it should easily rev to 6000 without a major loss of low speed tourqe.i would go with a 383 though all things being the same the engine with more cu.in. will make more power go with a 383 ltr designed motor build on the tourqe and try to harness it.look at iit this way(when racing)the other guy may have hp,make him catch you....(hp=tqxrpm)
87 trans am 350,L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,tb bypass,accel supercoil,hollowed maf,slp 3in. catback,a/c delete(whole lotta room in there now)
14.10@97mph w/2.01 60'
slp catback is finally on!!!
fastchip prom is in.OH!MAN!
FLOWMASTER S.U.C.K.S
Old Jul 16, 2001 | 09:07 PM
IROC-Z_85's Avatar
You're nuts
Old Jul 16, 2001 | 09:14 PM
IROC-Z_85's Avatar
AND WHERE THE HELL DO YOU GUYS GET YOUR MONEY
this sport doesn't like new comers one bit!
Old Jul 17, 2001 | 06:02 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
You should be OK with the stock bottom end.
As long as you don't have bad detonation and it runs good it will stay together.
Traxion is running low 12s on his STOCK bottem end and I'm sure there is some major high revving on it with that miniram.
Unless you plan to throw alot of boost at it later on with high revs, spend your money on the top end.
'88 RS (originally 2.8)
-350, .040 over, vette alum. L98s, stock tpi.
-305 injectors & chip
-TES headers & edelbrock cat back
-3.73 gears, 700r4.
Best with 2.8-17.4@77mph
Best with 305-15.0@93mph
Best with 356-13.7@101mph
on a 2.050 60 ft.
(Damn the 2.8!)
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
