Help needed here... really badly...
Old Jul 15, 2001 | 01:35 AM
Roshambo's Avatar
Ok, Ive got a 1988 T/A 305 TPI, I just replaced the heads with L98 Aluminum heads. I removed all emissions stuff, replaced my, spark plug wires, ignition module, and rotor. Everything is hooked up, the motor has been gone over tons of times. Here is my problem, the motor cranks, but, doesnt start. The head scratcher is this: I get 12 volts into the coil, and NONE out! I just replaced the OEM coil with a MSD Super coil about 1 month ago, I had the OEM coil laying here, so I tried it. Same thing.. no spark out of the coil. I thought it was the ignition module, so I just replaced that. Anyone have any ideas at all? This is driving me insane... please help!
-Roshambo
Old Jul 16, 2001 | 09:30 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
check one thing then post again there is a fuse on the driver's side fender for the ecm in a pigtail check that first(orange wire)it most likely will be the problem.if not go through the setup again check the coil and module
87 trans am 350,L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,tb bypass,accel supercoil,hollowed maf,slp 3in. catback,a/c delete(whole lotta room in there now)
14.10@97mph w/2.01 60'
slp catback is finally on!!!
fastchip prom is in.OH!MAN!
FLOWMASTER S.U.C.K.S
Old Jul 17, 2001 | 04:19 PM
Roshambo's Avatar
Well, my car is in the shop now.. which pisses me off, because Ive never had any problems like this before.. Im going out of town for a week, and the friend of mine who owns the place is cutting me a good deal, so It should be done when I get back.. Just for the hell of it, Ill post what was wrong with it.
-Roshambo
Old Jul 17, 2001 | 07:40 PM
89REDGTA's Avatar
If you come back and tell us it needed a new engine we'll know if you got taken for a ride or not! Just kidding. Good luck...
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
