What happens when air tube on cat is disconnected?
Old Jul 17, 2001 | 10:39 PM
Steve10's Avatar
I just noticed it was disconnected. I've been logging runs on the scanner and making FP and timing adjustments for the last couple of days. What would it affect?
Also, does 11.3 injector PW at WOT sound reasonable for my setup? I'm running the stock injectors. The AFR is always at 11.73 WOT.
'87 Formula WS6 - ZZ4 Crate TPI, ported heads, LT4 hot cam, 1.6RR, Accel runners, Accel lower, ported plenum, Edelbrock 58mm TB, pulleys, SLP cold air, headers and full exhaust, gutted cat, Walbro 255, Koni yellows, aftermarket panhard & LCA's.
Old Jul 18, 2001 | 04:01 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
I don't think it will affect anything your computer sees/reads. I may be wrong, but I think the idea is to pump air into the converter when the car is decelerating to reduce "bad" emissions out the tail pipe. My 81 Z and 83 Z have the small pipes going to the converter rusted out (who knows how long ago) but it never shows up as a trouble code on the computer.
Z's r Best
Old Jul 18, 2001 | 05:17 PM
87tpi420's Avatar
wont affect performance, only thing is emission gas will go up (maybe)
Old Jul 18, 2001 | 06:09 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
nox will go up.air isinjected into the cat to help the cats operation by adding extra oxygen it helps the cat burnoff the unused fuel that collected in the exhaust cycle.it shouldn't affect anything since your o2 sensor is before the cat and doesn't read what's going on in there
87 trans am 350,L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,tb bypass,accel supercoil,hollowed maf,slp 3in. catback,a/c delete.
oh!no!i think my maf is going!!!!!!!!!!!!
14.10@97mph w/2.01 60'
slp catback is finally on!!!
fastchip prom is in.OH!MAN!
FLOWMASTER S.U.C.K.S
1992 Trans Am
May 10, 2023 07:19 PM
FreeSpirit
Aug 29, 2015 05:47 PM
TheExaminer
Aug 26, 2015 04:59 PM
chazman
Aug 22, 2015 02:01 PM
drathaar907
Aug 6, 2015 04:20 PM
