AFPR help, problems after injector swap
Guys,
Just swapped from 24lb to 30lb SVO injectors, took me two days and once I finally get it back together I found that I was missing the vacumm fitting for the AFPR.. Its the small screw in fitting where you plug the plenum vacumm onto.
Can I get one of these new somewhere? GM?
Or a parts warehouse?
Thanks,
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 SR Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Thanks,
Brendan
you are talking about the little nipple sticking out of the plenum right? you might try a junk yard, or any auto parts store probably has the little nipples. it is nothing special, just need a small one for the small vacuum line. you may even try a hardware store in the plumbing section.if you find nothing there then you may have to goto dealer.
http://people.ne.mediaone.net/gdm/
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
