inline fuel pump
inline fuel pump
Does anybody know what cars (if any) an inline fuel pump could be scavenged from for a TPI swap? I know the better bet is for a new one, but money is tight right now, and if I could find a functional used one, I would use it. Any thoughts guys? Thanks!
you are talking to put in are car you put tpi in right? if so i think most pumps off cars with larger engines (not a corolla) will work. i am using a bosh pump inline on my car, i think it is from a mercedes or jaguar, i forget which but it is a high flow pump and i paid 0 for it. as long as you get one off a EFI car i think you should be ok
BUT... see if someone else posts a message, i may be wrong!
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
