373 gears
Old Jul 22, 2001 | 06:09 PM
Tuned Port Man's Avatar
373 gears
When you put gears in the car will the wine through the break down period or should they be quite form the get go.
Old Jul 22, 2001 | 06:17 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
If they whine now, they prolly will forever... The pinion depth or the backlash isn't set correctly although a small amout of whine comes from high geared performance sets but it's not 'overly' whiny
Old Jul 22, 2001 | 06:26 PM
Thanks for the help. I am going tho break the rear end back down tuesday and see if i can get it right.
Old Jul 22, 2001 | 08:00 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
It depends on what gears you have. If they are stock gears (GM) then they should be quite. If they are Richmond Gears, then they will whine cause they are cut differetly and are meant for racing, not for Grandma's Buick.
Gear whine will start around 40MPH and go from there. If you have driven more than like 20 miles, then changine the tooth pattern now will make them whine more.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Jul 22, 2001 | 10:13 PM
Vader's Avatar
I've got all the specs and data on the Saginaw (New Venture) rear ends, but they aren't specifically for TPI cars so I can't help you on the TPI board.
(Got the idea?)
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jul 23, 2001 | 07:06 AM
Kyle F's Avatar
Allmost eveyone I know that has not used GM original gears has whine. Even some Mudstains have them to.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
amcnellis
Sep 16, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
