Fuel regulator noise
Old Jul 24, 2001 | 10:53 PM
RODS92Z's Avatar
My fuel regulator is making a ticking sound. Its the stock one for the 305 that was replaced with a 350, prom, and 24lb injectors. Do I need a adjustable regulator?
Thanks for your help.
1992 Camaro Z-28 5.7L auto t-tops arctic white
1967 Pontiac Catalina 2 door fastback 400 v-8 auto cameo white dark red interior
Old Jul 25, 2001 | 12:39 AM
Yarnboy's Avatar
Dude, I think you are hearing your injectors..The fuel regulator should NOT be ticking. Is it doing anything screwy? Like are you not able to adjust pressure?
  • Red '88 IROC 305 TPI T-5 w/3.08
  • Accel 300+ Ignition
  • Accel 300+ Pro Sleeve Plug Wires
  • AC Delco Rapid Fire Plugs
  • Dual Friction Stage III Centerforce Clutch
  • Energy Suspension Transmission Mount
  • Flowmaster Force II 3 Chamber Cat Back Exhaust
  • Gutted Airboxes
  • Hypertech Stage II PROM
  • Hypertech Airfoil
  • Throttle Body Coolant Bypass
  • Best Maryland (40 degrees) E/T 14.686, 60' 2.205, 1/8th mile 9.461, 1/4 mile MPH 93.91
  • Best Florida (80 degrees) E/T 14.88, 60' 2.163, 1/8th mile 9.540, 1/4 mile MPH 92.74
  • Best 60' 2.163(Florida)
  • TPiS AFPR set to 42psi using Accel Fuel Pressure Gauge (Installed after Maryland run)
  • Aluminum Driveshaft (Installed after Maryland run)
I am looking to buy Edelbrock T.E.S. headers with the y-pipe. I am also looking for a 3.42 - 3.55 posi disc rear. cheesy@fred.net is my e-mail, send a letter if you can help!
Old Jul 25, 2001 | 11:07 AM
RODS92Z's Avatar
The injectors arent making any noise. I'm know its the regulator, not only can I hear the noise from it with a stethoscope, I can feel it with my hand on it. ITs stock original, not adjustable.
Old Jul 26, 2001 | 01:24 PM
Yarnboy's Avatar
I'd just go ahead and put an AFPR on there and port the plenum while you have it off. It's a good mod for a 350. I don't know what else to tell you man..
  • Gutted Airboxes
  • Hypertech Airfoil
Old Jul 26, 2001 | 03:21 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
You might be feeling the fuel pulses from the pump at the regulator, or from the injectors, but the FPR will not pulse. Inside is a diaphragm and a spring. The diaphragm is pulled back by vacuum pressure. That's it. Nice and simple. Pulses in the fuel line could manifest as a ticking as the diaphragm bounces against its seat.
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
