Fan temp
Old Jul 28, 2001 | 10:49 AM
wackytower's Avatar
Car: 1985 Trans Am
Engine: Superramed 406
Axle/Gears: 10 bolt 3:73
Fan temp
Is it possible to program the fan to come on via the chip? The reason I am asking is because I dont have my fan switch hooked up because of clearance problems bewteen the head and the headers I just had the little plug that goes on the A/C unpluged so the fan would run when the car was started. So yesterday I plugged the plug to the A/C and the fan came on at 170.
I have a custom Ed Wright chip
Old Jul 28, 2001 | 10:58 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
If you have electric fans, the answer is "generally yes you control them through the ECM".
Why I say "generally" is because the ECM on a dual fan car only controls Fan #1, the ECM does some checking on Fan #2 but the ECM cannot turn it on; GM did not put a driver in the ECM to turn on Fan #2. You need to change the Fan Temperature Switch in the passenger head to control the temperature that Fan #2 comes on.
Also, in the ECM, you can modify the "MPH" that Fan #1 turns off when you have the A/C on, along with the temperature. Generally, if the A/C is on, Fan #1 will remain on until you reach just over 35 MPH.
Old Jul 28, 2001 | 11:05 AM
wackytower's Avatar
Car: 1985 Trans Am
This is for a 1985 TPI with the single fan. So what your saying is that I dont really need the fan switch hooked up. Thanks
sheachopper
Jul 31, 2019 11:27 AM
Fanatic1074
Oct 2, 2015 03:47 PM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
