prom
prom
i want to get a new prom burrned and a i noticed that a few companies want to know the stock prom 4 letter code. my car allready has a hypertech chip so i dont know what the code is does anyone know it. the car is a 91 Z28 5.7 auto with 3.27 gears
91 Z28 slp headers adj reg accell cap rotor coil comp cam roller
random tech cats flowmaster catback
Car: Take
Engine: Your
Transmission: Pick
They want that so that they have a starting point, then they just modify that to your personal specs. If you have a 5.7L, then the most common one is AUJP. Thats what I use as a base for PROMs that I do. Hope this helps.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
Car: Death Mobile
Engine: 666 c.i.
As GM Tech said, for SD L98s with 3.23s, AUJP1350 was the stock Memcal's Broadcast Code. The replacement Memcal Broadcast Code is AUJP1615. The only difference between the two is the Date and Sequence Number.
BTW, your car has the 10 Bolt 7 5/8" Saginaw 10 Bolt 3.23 rear end. The BW Australian 9 Bolt 3.27 was no longer offered in 1991.
