heads and cam combo
Old Jul 24, 2001 | 01:50 AM
Iroc n roll's Avatar
heads and cam combo
Tell me what you guys think of this combo. Scoggin D's high performance rebuilt Vortec Heads (#SD8060) and Lingenfelter's Hyfraulic Roller cam (#74219). That is if Scoggin D ever comes out with the Vortec TPI manifold. Are there any other better combos out there for the money and that go with my mods below. I'll probably have a chip burned after the combo so PROM issues are irrelevant. Keep in mind that the intake will probably cost an extra $450. I really like the cam so if there are any better suited heads for it let me know. BTW I'm currently using 1.5 rockers. Any info would be a great help.
"Though I cruise through the valley of Rice I shall fear no turbo, for torque art with me."
1985 IROC-Z, 305 out and 350 L98 TPI engine in, Hooker Headers, 3" Hooker Cat-Back, 3" CatCo Cat, Rebuilt TH700R4 with Shift kit, 3.73 Richmond gears, Auburn differential, Accell SuperCoil, Accell 8.8 racing wires, BBK AFPR, Homemade Ram-Air (thanks to Anris Skulte), Dropped A/C, Hurst Dual Gate Shifter, Air Foil, and more to come
Old Jul 25, 2001 | 11:39 PM
No opinions?
1985 IROC-Z w/T-tops, 305 out and 350 L98 TPI engine in, Hooker Super Comp Headers, 3" Hooker Super Comp Cat-Back, 3" CatCo Cat, Rebuilt TH700R4 with Shift kit, 3.73 Richmond gears, Auburn differential, Accell SuperCoil, Accell 8.8 racing wires, BBK AFPR, Homemade Ram-Air (thanks to Andris Skulte), MAF screens removed, Dropped A/C, TB coolant bypass, Hurst Dual-Gate Shifter, Air Foil, K&N filters, Holley performance fuel pump, Spohn Subframe Connectors, Re-located Spohn Lower Control arms, and more to come.
Old Jul 26, 2001 | 12:05 PM
FormulaJoe's Avatar
That 74219 cam is a single pattern cam. I would think the vortecs would work better with a dual pattern camshaft because the exhaust flow isnt that great on the vortecs.
Any other opinions? What about lingenfelters 74211 cam?
Old Jul 26, 2001 | 12:24 PM
91-ZZ4-Z28's Avatar
I think the AFR 190's or the LPE ported D port heads out flow the vortec's and you dont have to wait around for a new intake.
1991 Z28 ZZ4 with LPE superram base, SLP runners, LPE 58mm T-body,Random Technology ramair,TES headers,24#svo injectors,ZEX nitrous,Walbro 255lph f-pump,Accel AFPR,Random Technology catback,!cats,and mutch more.
Old Jul 26, 2001 | 05:25 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I agree. There are many other heads out there that are readily available, with the right bolt pattern, that are as good or better than the vortecs. Don't get me wrong, the vortecs (and/or fastburns) are very good heads - a friend of mine has them (untouched, out-of-the-box fastburns) on his low 10 sec N/A 406 Nova - but if you want to be able to buy the rest of your parts now, the vortecs are not the way to go.... There is also the issue of only one company making a TPI intake for the vortecs.... I wonder how much they will charge for that since they are the ONLY ones putting one out...hmmmmm
1987 GTA L98 MD8 GH3
355 '97 Vortec 4-bolt block, TRW(suck) forged pistons 10:1 CR, TFS 23*, LT4 Hot Cam, Ported plenum and intake, SLP Siam Runners, BBK 52mm TB, Edelbrock TES, gutted Cat, Flowmaster, CAI w/K+N cone, AFPR, TB bypass, !AIR, !A/C, !EVAP, ARAP, 2300 stall, Alum. Driveshaft, Hotchkis STB, '99 Camaro seats.
Coming Soon!!: Fourth gen 3.42:1 rear, Spohn LCAs and Panhard.
Old Jul 29, 2001 | 10:28 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
I was going to use my Vortecs on my motor but decided I couldn't hold my breath any longer. The Vortec's are good factory heads, but I decided to wait for some used AFR 190's or TFS heads. SD blew it, as many others, we've been waiting for over a year. The aluminum heads will allow me to run a higher compression ratio safely without detonating, anyway. Factory CR with Vortec is 9.4:1
84z96L31vortec
Aug 20, 2017 12:16 AM
michealleger
Aug 26, 2015 03:29 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
