HEllllllllp i searched the fourms btw and hello all
Old Feb 15, 2008 | 09:01 PM
alwaysthenewbie's Avatar
Hello all i have searched all the fourms for the anwer noting as strange as this i tried starting it nothing i tried agin and all hell broke lose there was the stangest noise comming from under the hood and possibly under the car i removed the key and the noise contined till the battery went dead my first thought was that its a short still is but it was just strange. I poped the hood and bloodhounded the smell it stoped at the distibouter but i wasnt really sure because it was windy. but it was on the passanger side and the nosie seemed to be comming from the center of the car. Now the car wont turn i tried charging the brand new battery and it wouldnt take the charge at all. Im thinking some kinda of motor burned out or somthing this is my only car and im not able to afford another i just need it running weither its rigged or whatever i love it but if i cant get to work there is no way i can acutally rebuild it the way i would like and im thinking a swap but i dont have the tools nor know how to perform this.. Any info would be appreciated thanks alot everyone
Old Feb 15, 2008 | 09:20 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: HEllllllllp i searched the fourms btw and hello all
welcome aboard, well to start with id say what kind of noise ,what did it sound like?sounds like the starter from what you described,probablythe bushings have worn out and it shorted like you said. they get worn ,then the armature will short to the field. unhook the battery cables,remove starter and replace.charge the battery with cables unhooked to see if it will hold a charge.hth,later jimmy
Old Feb 15, 2008 | 09:27 PM
no wasnt the starter im alomost sure it sounded more like the fuel pump and the smell came from the the passanger side under the hood but the sound came more or less from the middle or drivers side and underneth the car
Old Feb 17, 2008 | 08:03 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
I would still say starter motor...... just because it "sounds like" it is coming from one place, does not mean it is really coming from there.....
Old Feb 17, 2008 | 01:11 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
fuel pump is in the tank, not by the engine.
Old Feb 17, 2008 | 01:25 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
the area you talk about is directly north of your starter my says starter also
Old Feb 18, 2008 | 03:36 PM
ok guys im checkin that asap i just didnt think a starter motor would cause all that mayhem .. and just askin would it drain the battery too ? man i wish you gues could have heard it that would have simplifed it lol thanks guys..
Old Feb 18, 2008 | 03:52 PM
89RS_82Z's Avatar
if it gets a dead short in it, or in the solenoid, than yea it will, take it off and take it to your local auto parts store and have them bench test it, im pretty sure without being able to look at the car or hear the sound, that you problem is in your starter
Old Feb 18, 2008 | 03:56 PM
kanmudhog's Avatar
Car: 89 formula ws6
Engine: yes
Transmission: yes
Axle/Gears: both
The starter will draw huge amounts of power , thats why batterys are rated in cold cranking amps - the cranking part is refering to the starter .
I agree with everyone it's your starter .
Old Feb 29, 2008 | 08:55 AM
Thanks everyone it was the starter LOL it was torn to bits on the inside i got it up in running in no time but was amazed that it was torn to bits like that on the insde burnt to a crisp i am still suprised at the fact that even with the key turned off it still did that damage so im going in for futher ispection as soon as i have time so it dosent turn into somthing major BUT THANKS AND NEXT TIME HOPEFULLY I WILL BE GIVING ANSWERS NOT ASKING QUESTIONS LOL
F-body-fan
Jan 12, 2023 01:49 PM
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
paul_huryk
Oct 1, 2015 04:27 PM
kkirch15
Sep 30, 2015 04:44 PM
