Holy Smoke
Old Jul 2, 2001 | 07:43 PM
lindseymillar68's Avatar
Holy Smoke
When I start my 88 Trans-Am 305 Auto, there is a giant puff of blue smoke- when starting cold or hot, but it doesn't blow any smoke during normal running conditions. The smoke smells alot like gas. Could it be valve seals? why would it smell like gas? thanks for your input.
Old Jul 2, 2001 | 08:26 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Nice car by the way a very good choice.
blue smoke is usually oil and yes It could be your valve seals.
however if you smell gas I think it could be a leaky injector.
if it doesnt also smoke at WOT I would say it is your seals.
88 WS6 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
free mods, dynomax catback, urethane motor+trans mounts,
SSM SFCs, Bilsteins
very trick homemade ramair, Accel 300+ ignition system.
Planning: hedman 1-5/8 longtubes, NOS 150 plate, world 305 heads, replace the "peanut"! and other susp. mods.
check it out at:
http://www.geocities.com/transam617
Old Jul 29, 2001 | 05:36 PM
Crusader's Avatar
Car: 1988 Firebird Formula
Axle/Gears: 3.45
You use synthetic oil? I've noticed in my 88 GTA that with out synthetic it puffs blue when it starts but with it it doesn't.. Kinda strange but ya know....
Jess
Old Jul 29, 2001 | 06:41 PM
u r sofa king we tah did's Avatar
thats cause synthetic oil combusts differently than regular dino oil. but the puff of blue smoke on start up is bad valve seals.
Old Jul 29, 2001 | 07:55 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Actually, synthetic oil is just molecularly perfect. It can slip past seals that regular motor oil cannot. That's why sometimes car that use synthetic oil leak oil when regular oil in the same car will not leak.
Rob
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
