T/B coolant by pass
Old Aug 2, 2001 | 07:10 PM
Going Slow Sucks's Avatar
T/B coolant by pass
I was in the free mod section and i came across the T/B coolant by pass mod. I can't see what your supposed to do with the coolent that comes out of the intake manafold. Can some one tell/show me how to do this the proper way.
thanks....
88 Camaro IROC-Z
350TPI
K&N filter , High flow exgaust (no cat's), automatic tran's shift kit
Old Aug 2, 2001 | 10:08 PM
Guest
Guest
Posts: n/a
If you follow the hose through the throttle body, you will see it connects to a hose that runs to the heater core. You can either splice them together or replace the hose.
Old Aug 2, 2001 | 10:52 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
i got a 90* elbow from home depot screwed it in the intake gott another hose from thhe auto store(longer than stock)ran it from the hot water valve right tto tthe elbow easiest way to do it
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch,tb bypass,accel supercoil,cap& rotor,hollowed maf,slp 3in. catbcak.
FOR SALE!FOR SALE!FOR SALE!FOR SALE!FOR SALE!
EVRYTHING IS FOR SALE WITH MY CAR (EXTRA ENGINE,TPI INTAKES,RUNNNERS,PLENUMS,ECM W/CHIP,ETC.
GETTING OUT OF THE 3RD GEN MARKET BEST OFFERS
CONSIDERED!!!!!!!!!!!
sheachopper
Jul 31, 2019 11:27 AM
racereese
Oct 3, 2015 03:46 PM
