How can I verify this is a ZZ4 cam? Stamp #'s?
Old Aug 2, 2001 | 06:32 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
I want to verify that what I have is in fact a ZZ4 5.7l cam before installing it. Is there a certain stamp number I should see?
There are several # stamped on each end.
Rob
High Performance & Party page
Pics of my rides past & present and recent party pics!
89 TTA #426 20th Anniversary turbo 3.8 bone stock
79 TA 6.6l - all original stock
94 Silverado Tuned Port Injected
87 Grand National- lil' ole V6, 12.40 @ 108 w/1.79 60'
95 Trans Am Conv.- LT1
Old Aug 2, 2001 | 08:04 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
There isn't a "ZZ4 Camshaft". The ZZ4 "CRATE ENGINE" uses the ZZ3 camshaft, P/N: 10185071
As for stamped numbers, mine has: "179 99R 071 FM54"
I hope this helps.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Aug 3, 2001 | 09:33 AM
2QUIK6's Avatar
Mine is not stamped with those numbers, mine has 193 00L 071 FM14 ???
Anyone have any idea?
Old Aug 3, 2001 | 11:46 AM
long&low
Guest
Posts: n/a
Mine has the #s 006 99R 071 WB36
Old Aug 3, 2001 | 12:30 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
If I had to guess, the 071 is the defining factor and they're probably all ZZ3 camshafts.
Old Aug 3, 2001 | 05:54 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yeah, I think the "key" is the "071" since it is the last three digits of the Part Number. I'd say its genuine.
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
skeltor
Feb 2, 2016 10:37 AM
Jorlain
Oct 8, 2015 01:57 AM
webeeZ28
Sep 14, 2015 12:00 PM
Ian Irvine
Sep 4, 2015 08:08 AM
masonta
Sep 1, 2015 06:40 PM
