cam for 96 vortec 350 with TPI
Old Feb 21, 2008 | 08:07 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
specs are 214*/220* duration @ 0.050 .452/.465. comp cam
friend overed this to me. it will go in a 96 vortec 350 with TPI. what do you think about this one? the car will be driven alot. needs to be streetable. basically stock. getting headers soon and a X pipe.
I don't know much about cams alittle help?
Old Feb 21, 2008 | 11:35 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: cam for 96 vortec 350 with TPI
Is that the Compucam 2032? The '96 Vortec truck engines were the first truck engines that came with roller cams. If that is the 2032 it will go right in. Its a little outdated by today's standards but it wake up any engine and still work with the stock Vortec valve springs.
But if you want to swap in better valve springs for more lift I recommend the Manley 22410-16 springs and 23652-16 retainers.
Old Feb 22, 2008 | 07:04 AM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
I used a spring kit from Crane # 10308-1. The kit fits iron head LT1 and Vortec heads and the heads do not need any machining for the springs or for more lift.
I forgot what lift they will allow, since it's been a couple years, but you could look them up at Crane, jegs, summit, etc.
I used a used LT4 stock cam for 20.00 off vette forum.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
camaro71633
Sep 1, 2015 10:24 AM
Sanjay
Aug 12, 2015 03:41 PM
