engine vibration........ revisited
Old Apr 5, 2001 | 06:47 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
well i have eliminated alot since the last time i have post about it. I know it is the engine not tranny or flex plate/torque converter. I have also changed the balancer, plugs, wires, distibutor. I checked timing and besides a little flux it is on 6 deg btc. The timing chain is 1 year old and a double roller. The compression on all is between 135-145 psi. I have tried to pull the inctectors to see if any of them drop more than the other, with little change. I need a direction before i tear into the motor. It has been suggested the one of the springs is toast or a bent push rods..... Please point me in the right direction thnx THE SHAGGY( THOUGH NOW DEFUNCT) IROC:ROLLEYES:
'89 SHAGGY IROC
L98 7r4, all free stuff,T.E.S.,HOOKER CAT BACK,KYB,ACCEL8.8,JET fan sw. etc.
so much to do , so little money
Old Apr 5, 2001 | 08:13 PM
i forgot , no codes. Also it smells really rich at the back. Oh and it only seem s to happen after the motor is at temp(185deg)
Old Apr 29, 2001 | 11:56 PM
back again, with an update........ I found out i had 4 bad fuel injectors. So that was the reason for the vibration at 1800 rpm. Now i have a vibration at 1600 rpm. The motor is smooth and the exhaust sounds very smooth, but in side the car the is a resonance. I also seem to have a vibration at 3000 and higher. Again this is all with the motor at temp. Also it is not the trans or T/C, as i have disconnected them and it is still there. I am wondering about fuel pressure? I have the 24 lbs SVO injectors set at 50 psi. Is this important? I don't seem to have any vacuum problems as i just put the whole intake and higher back toghether with new everthing.
'89 SHAGGY IROC
Old Feb 22, 2008 | 07:37 AM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
Re: engine vibration........ revisited
How did you make out with all of this?
Old Feb 22, 2008 | 10:01 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
I can't remember anything after about a month but 7 years???????
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
