why is my plenum resting on the AFPR
Old Aug 3, 2001 | 12:54 PM
camaroguy99's Avatar
Do you guys have this problem? When I put my intake back together the plemun is resing on the AFPR. I've tried 2 different ones (BBK & Holley) and they both are too tall. Do I need to take out that metal spacer ring in between the diaphram? Anyadvice would be great because as it stands now, I have to take off the intake to chenge the fuel pressure. Thanks
Jim
Oh BTW, If you're buying a AFPR get the Holley . The quality is so much better then the crappy BBK piece. I just wish I had figured this out before I spent 60 bucks for the BBK one
Old Aug 4, 2001 | 01:17 PM
sparks383iroc's Avatar
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
I have the Crane AFPR. It is kinda of tight under the plenum, but there is still enough room to make adjustments.
Can you grind a little off the bottom of the plenum to give you some room to adjust the pressure?
Sparks a flyin'
Old Aug 4, 2001 | 02:59 PM
I could but that would require taking of the plenum again. Is there enough meat there to grind away like 1/8-1/4"? I think thats about what I would need to make it function properly. I will probably do that if I have to adjust it again. Thanks sparks.
Anyone else?
Old Aug 4, 2001 | 11:18 PM
rezinn's Avatar
Turn the screw all the way in and you won't have the problem anymore
Old Aug 5, 2001 | 11:06 AM
87tpi420's Avatar
on my afpr i cut a peice of allen wrench and stuck it in the hole with a tad bit of epoxy so it wouldnt come out. and then it makes it easier to reach in there witha small open end wrench to adjust it.
i dont have that problem anymore with super ram!
http://people.ne.mediaone.net/gdm
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
Old Aug 5, 2001 | 02:17 PM
It's not that I can't reach the **** to turn it, the porblem is it's wedged under the back of the plenum and won't turn
One other thing, it could it be the combination of aftermarket TPI parts? I have the AS&M SSLTR and a TPIS base. could that cahnge the height of the fuel rail or lower the plenum? What about the spacers TPIS tells you to put on the fuel rail bolts? are those compleately nessacery? Now that I think about it that might be my problem. they add like an 1/8 to the height of the fuel rails. Thanks and sorry for the book.
[This message has been edited by camaroguy99 (edited August 05, 2001).]
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Oct 3, 2015 01:25 PM
