BASE AND RUNNERS
BASE AND RUNNERS
OK one more time time, I am looking at getting a new base and runners. What's the best--TPIS, ACCEL AS&M etc. Which one? I would really like to change cam and heads but won't happen for about 2 years. What should I get?
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have no clue just put them on and the car is in 4 the winter. Havent even started it up with the new combo yet. Very nice pieces though. esp the runners.
Hey Mkos where is Independence Ohio? I am in Ontario but only about 1 hour from Toledo. Just curious. I'd like to know what you think of the new intake when you get it running.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I agree with Mkos. Accel runners are also pretty good, but they're cast.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
The BEST?
TPIS Big Mouth Base and AS&M Large Tube Runners. That is the BEST combo.
If you want to save money then buy the Edelbrock base and port match it yourself. Then and only then will it be equivalent to a TPIS base.
Don't get any runners except for the AS&M runners. They flow the best.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's after installing Hooker LT Headers and reducing weight.
Moderator: PROM board at thirdgen.org
Tim
Should I be able to knock off a couple of tenths in the 1/4 with just changing the base and runners. Besides the mods below I have also ported the plenum. I want to run solidly in the 13's all the time but don't have $$$ right now for complete rebuild.
Bob,
it seems to me that ever since you started modding your car since the 13.88 1/4 mile it has gone slower.. you obviously had a perfect setup. everything was working perfectly with everything else.. i would just leave the car alone, it looks like that you are throwing things our of balance and therefore going slower.
JUST MY OPINION.
JUST MY OPINION.
I have the Edelbrock HI-Flo base and love it. I am also using SLP runners that I will be modifying over the next few weeks to add additional air flow. I had no problems installing the base and it seems to work very well.
1989 Pontiac Formula L98 Ported Plenum, Edelbrock 6085 Heads, Edelbrock HI-FLO Intake, BBK 52MM TB, Edelbrock TES, FlowMaster 3" Exhaust, Dual Cats, 3.27 Gear, CompuCam 2032 Cam, 1.5 Rollers, Ed Wright FastChip, Accel Super Coil, MSD 8mm Wires
You don't think that increasing airflow would help??? Isn't that the whole idea of making more HP? More air + more fuel = more HP!!
I'm sure it probably needs new plugs and wires which may account for it losing a few ponies.
I would think that a new intake should help!
Bob
Bob
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
<font face="Verdana, Arial" size="2">Originally posted by fast89:
</font>
</font>
If fast89 doesn't get around to reading this do any of you other 3rd gens have any idea how well this combination works?
I have considerable other internal modifications and I sure don't want to start it up with the stock TPI on it. I have until the middle of this week to make up my mind.
Thanks in advance!
_ ___ _
SMasterson
I'm just finishing the installation of the AS&M runners and TPIS base. From what I have heard this is the best combo out of the box, but people have had better results porting the hell out of the SLP runners and running them. I just didn't want to spend the time grinding away on a set of runners (and possibly destroying them)
Make sure you get the semi siameesed (sp?) runners they are a little more but well worth it. You have to get them from AZS&M I don't think TPIS carries those, just the LTR.
Royal_Z
Sep 30, 2015 08:45 PM
