help
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
help
ok I'm gonna post this question here cause I posted it somewhere else and all I got was a dumb response.
I have an 86 Iroc Z with 350TPI, when I start it, it takes a long while before the RPM's come down and if I shift into any gear before the RPM's go down it hits very hard. It doesn't matter whether the engine is cold or warm.
Any ideas......this is driving me crazy.
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
Good question, I would like to know the answer to this one, because my friends 91 RS does the same thing!
j.wolfe
_ ____ _
91 GTA L98
Best time: 14.389@95.49 (VIR)
"...Deception..." Brandon Sloan * ...wounds heal and chics dig scars...
j.wolfe
_ ____ _
91 GTA L98
1FastZ,
You may have a sluggish IAC. HAve you tried removing the IAC, cleaning the air passages, and cleaning/lubricating the IAC pintle?
Just a possibility.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Just a possibility.
Later,
Vader
I had an 85 TA that did the same thing when the throttle body was clean it would go up to 2300 rpm and then very slowly go down to a very smooth idle. I tried everything and it never got any better! My 89 never does that, I have no idea what the difference is.
14.48@93.72mph 2.03 60 ft
After Pulley's 14.31@95.18, 2.14 60 ft
