what do u think this combo will be worth
i have an 85 trans am LB9 and this winter i plan on getting a few bolt ons for it. I want slp siamesed runners, an SLP CAI kit, SLP stainless emmisions legal headers and an SLP air foil. I already have a dynomax cat back and a catco high flow converter, the car has just been tuned up as well with accell 8.8 mm race wires with matching cap and rotor. what would i run in the quarter after the mods as well as now? remember i have an 85 TPI so i got the L98 cam
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
http://www.geocities.com/firebird/myfirebird.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
1985 trans am
4 wheel disks
16 inch wheels
305 TPI
t tops
weak sauce...i have the l98 cam, high 14s to low 15s if you EVEN get that...if not...low 15s to mid 15s...auto tpis suck hard = /
1990 G92 5spd LB9 - 3.42 80,000 miles
Accel Ignition/Wires (8.8mm), Advanced Timing, TB Bypass, Ported and Gasket Matched Plenum, Synthetic Motor Oil, 160 Thermo, TPIS Airfoil, K&N Air Filters, Centerforce I Pressure Plate and Clutch, Edelbrock TES Headers, Dual Cats, Edelbrock RPM Series Catback, Homemade Ram Air, Bosch +4 Platinum Plugs
14.4 @ 94mph w/2.0622 60ft (w/o headers and catback)
14.426 @ 96.19mph w/2.167 60ft(w/headers and catback)
Also newly modded w/o track times:
Holley AFPR, Underdrive Pulleys, KYB Shocks and Struts, Crane Ignition
huh?? no way i raced my friends z28 TPi on a quarter mile stretch and he ad a g tech in his car, he ran a 15.3 at like 92 mph and i was a nose infront of him. no way your gonna tell me that my L98 cammed TPI car runs the same as most TBI autos, and please dont respond by telling my that TBIs run mid 17s becouse one in proper tune should be capable of low 16s high 15s even better with a manual so lets keep it real. i just wanted to know how the SLP set up would have worked out for me....
Car: 89 Iroc
Engine: 305TPI
You will be in the 14's no problem at all. I am guessing that you will be in the low 14's with the combo that you have with a good launch. 90Iroc is right Auto TPI's are slow but those are with the peanut cam. He has the good (stock) cam in his car so if you shift right you are good for 14.3ish. Just my guess. Good luck and post your results.
thanx for the comments, i plan on doing the cold air kit and air foil this fall so ill let u guys know how i like it, I am assumeing its going to be a nice peice especially with the air foil and exahaust my little 305 will be flowin
skinny z
Oct 5, 2015 06:23 PM
