What belt do you use with March Pullies?
Old Aug 8, 2001 | 03:30 PM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
I have the three piece pulley set (crank, water pump, and alternator). The belt I have on there has stretched and the tensioner is now out of the normal operating range. The belt number that I have been using (as stated in March's instructions) is p/n: 6PK2400, but it doesn't bring the tensioner back to that range as much as I would like. I think the belt I need, should be a bit shorter than this one, so what number should I look into?
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
88 IROC-Z -- 350 L-98, 700R4, Flowmaster, Edelbrock Headers, Catco Cat, K&N, MAF Sceens Removed, Airfoil, March Pullies, Comp Cams Magnum 1.6 Roller Rockers, Bosch Platinum Plugs, Accel 8.8 mm Wires, MSD 6AL, Hypertech Cap & Coil, Hypertech Chip, Hotchkis Strut Tower Brace
Old Aug 8, 2001 | 09:33 PM
82z's Avatar
82z
There should be another number on the belt. Usually around 1800-2300. That is the length in cm. A good parts guy should be able to help you out.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Aug 8, 2001 | 09:52 PM
IROCET's Avatar
Engine: 5.7L
Yeah, I would assume that the number you are reffering to is 2400. The part number at the parts store is 5060945, the 945 is for 94.5". This is the belt I am running now, but I think it needs to be shorter by a bit, but I don't know how much. The tensioner is not going back to the proper location when it is applied. This is not going to be a stock size belt because of the pullies.
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
Old Aug 9, 2001 | 10:42 AM
chiefz28's Avatar
<font face="Verdana, Arial" size="2">Originally posted by IROCET:
Matt
</font>
yes you need to get a shorter belt forr thoses pullies.I just replaced my belt but can't remember the part number I have the 3 pc also.What I did to get the right sizr in the begining was I took a piece of string routed it as the belt would go pulle it tight mark/tie it the took it to the parts store and at the time had a neat tool they put in on to measure it and I was on my way
1991 1LE Z28 355cu 5SPD (ORIGINALLY 305 BEST E.T. 14.186@99.86mph)NO PASSES ON 355 YET.MINI RAM INTAKE,AFR 190 HEADS,10.23:1cr 24# SVO INJECTORS,BBK 52mmTB,AFPR
FULL ROLLER MOTOR,1.6 rockers MSD 6AL
AUTOMETER A/F GAGUE MARCH PULLEYS,HEDDMEN HEADERS 3IN EXH NO CATS FLOWMASTER,POWER TRAX NO-SLIP LOCKER,3:42 GEARS,LAKEWOOD LOWER CONTROL ARMS HOTCHIKS STRUTTOWER BRACE,COMPETTION ENG.SUBFRAME CONNECTORS
MALLORY TACH W/SHIFT LITE
BLACK, TINTED WINDOWS, TAIL LIGHT COVERS BIG BLOCK COWL INDUCTION HOOD,SHAVED DOOR HANDLES
67RS 327cu 92K ORIG MILES.NEWER GM HEADS HEADERS,650 HOLLEY CARB,CAM, 350 TURBO TRANS W/SHIFT KIT&COOLER 12 BOLT POSI 3.73'S MUTLILEAF SPRINGS
NEW VINYLROOF&CARPET, COWL HOOD,HIDE AWAY HEAD LITES,
Thirdgen89GTA
Nov 26, 2015 11:04 PM
bigjay89gta
Oct 15, 2015 08:04 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
