Code 36 Anyone??
Old Feb 27, 2008 | 01:45 PM
cjames9001's Avatar
Car: 1986 Trans Am WS6 Pkg.
Code 36 Anyone??
Ok so I know this isnt exactly the cheapest way to be going about this but with my '86 trans am TPI 5.0 Auto transmission ive been getting an ses light for code 36, Burn off at mass air flow sensor OR Problem in transmission shift OR Fault in direct ignition system OR Missing pulses in electronic spark timing signal, I just finished rewiring the connector for the MAF sensor burnoff relay, replaced the MAF sensor burnoff relay, replaced the MAF and yet im STILL getting this code 36, i just had the transmission rebuilt, so im not so sure its that... the only thing i can think of is possibly i wired the connector wrong? the code only sometimes comes up but it always comes up within 5-10 seconds of the engine running... does anyone have any suggestions? anything would be greatly appreciated!
Old Feb 28, 2008 | 12:50 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Code 36 Anyone??
the TPI board for code 36? This is a pretty common thing for MAF TPI cars.
Old Feb 29, 2008 | 07:46 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Go back to witts end. I have a present for you.
Old Apr 14, 2008 | 09:55 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Alright, well I am having a problem with a friends car who is getting a code 36 and have been searching for 20 minutes only to find other posts where people say or just give generic "Code 36 is the burn off and it does this..." every few years these questions need to be answered lol otherwise I'll never find info on it.
Old Apr 14, 2008 | 10:59 PM
Guest
Guest
Posts: n/a
A weak battery will almost always trigger a code 36 on startup. If thats not it, replace the maf power and burnoff relays and check the wiring because the wiring goes bad at the connector.
Old Apr 15, 2008 | 12:50 AM
cjames9001's Avatar
i dunno if anyone has made this mistake before but i put the MAF burnoff relay where the MAF power relay was supposed to be and vice versa with the MAF power relay and it was causing me a code 36, the second i switched them around the code went away and hasnt come back since...
Old Apr 15, 2008 | 11:24 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: Won't Idle!!! AT WITS END!
36 MAF sensor burn-off voltage was missing. Check MAF sensor burn-off relay and terminal "D" on MAF
There are two Maf relays one for burn off and one for power.
The power one has heavier contacts for more amperage. It can replace the burn off but not the other way around.
For the $11 az to $14 gm, it good to just replace both. I use the heavier one in both places for ease of trouble shooting.
This Voltage (edit maf burnoff) only happens at key off and for just hot sec.
Won't throw the code till the next start up. So... everytime ya gata unhook battery, to clear the code, then start stop start recheck for C E L
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
