ported plenum on a305
Old Aug 10, 2001 | 07:36 PM
84zeddd's Avatar
Any gains in porting a 305 plenum
Old Aug 10, 2001 | 09:27 PM
DON 88T/A's Avatar
If you have other intake mods such as filter,cold air,foil,ported mass air meter....yes it will help a bit.
You need to attack the intake as a whole to really reap any gains.
I have a ported plenum on my 88 305 TPI along with the above mods and it runs very well.
Old Aug 10, 2001 | 09:49 PM
Vader's Avatar
84,
The plenum bores just behind the throttle body are the single most restrictive point in the induction system, so it would only stand to reason that there would be some advantage. As stated, these advantages will be more apparent as teh modifications continue, but for the cost of a set of plenum gaskets it's a good start.
If you are more curious, check this file:
Plenum Porting.pdf
You'll nedd Adobe Acrobat Reader to open the file (see below).
Later,
Vader
"Let the bodies hit the floor!"
Old Aug 10, 2001 | 10:55 PM
R.O.B.'s Avatar
My first mod was to port the plenum. It didn't feel any faster, but it did feel much smoother reving up in the rpm's. Adding the headers is what gave me the biggest gain on the 305.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
48psi regulator, (Nickel method)
Old Aug 10, 2001 | 11:13 PM
Guest
Guest
Posts: n/a
<font face="Verdana, Arial" size="2">Originally posted by Vader:
The plenum bores just behind the throttle body are the single most restrictive point in the induction system</font>
Why didnt anyone tell me???
Cant wait to see what happens when I knock these walls down... see if I cant push the HP up a bit more. Think I should do it? This is on the engine with the siamesed base btw... told you the plenum wasnt ported.. heh...
Yea, it can help, anything can help on a 305... it needs all the help it can get.
[This message has been edited by madmax (edited August 10, 2001).]
Reid Fleming
Oct 10, 2015 09:56 PM
toronto formula
19
Oct 6, 2015 12:27 PM
bplessy
Sep 30, 2015 12:14 PM
