Effective "emissions" mods?
Old Aug 13, 2001 | 02:48 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
I may have to (within the next several months) pass CT emissions. Right now I have an 89 Iroc with a 135,000 mile LB9 with bad valve seals, no cat, and air system removed (egr and charcoal intact.) So basically I want to pass emissions without spending too much money or screwing up the car - that's pretty much what I care about. Here are things I'll do for sure:
1) warm the car to at least 210-220 degrees and drive for awhile before the test..etc.
2) full tune up including o2 sensor and oil change.
Now for the questions.
1) A new cat/air injection setup will probably cost more than $200. That's about how much it will cost to get into prom burning. I will definitely do one or the other, but I'd sure like to do the prom method since I want to get into that anyway. Does anyone familiar with burning proms know what kind of results I can get with this method? I might post this over there, but I figure a good deal of the prom burning crowd is also in the tpi crowd...
2) How much does retarding timing (say to 2 degrees btdc) and/or leaning the mixture and messing with idle and things of that sort help? Does anyone have specific advice in this area?
3) >>if all else fails<< What effect will using denatured ethanol have? It seems this works for a lot of people. How should it be mixed with gas, like is 1:1 acceptable or what?
Thanks in advance for any advice or opinions, especially specific info!
[This message has been edited by I ROCK (edited August 13, 2001).]
Old Aug 13, 2001 | 02:46 PM
red350Z's Avatar
i wouldnt worry about thr smog pump i dont think it will make a differance and i have never had them look under the hood of my car. i know some people that have used alcohol in there gas to pass the test but dont know haow much. were in Ct are you from. im from bethel.
91 Z28 slp headers adj reg accell cap rotor coil comp cam roller
random tech cats flowmaster catback
new motor in
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
