why am I tearing up my AFPR?
Old Aug 12, 2001 | 07:16 PM
camaroguy99's Avatar
In case you didn't read my other post, I have torn the diaphram on the FPR twice now. First the stock one and now the holley unit. What could cause this? And in a related question, where exactly does that metal spacer ring go? Between the two seals on the diaphram? thanks
Jim
Old Aug 12, 2001 | 07:41 PM
Vader's Avatar
Jim,
The metal ring with the six holes in it is NOT a spacer. It is a load ring, and is the last thing that goes on the assembly. It sandwiches the spring can between itself and the regulator base. The screws are screwed throough the ring first and the screw heads rest on the ring, not the spring can itself.
The purpose of the ring is to distribute the load of the spring can equally among the screws and prevent the thin edge of the can from distorting and allowing the diaphragm to migrate, tear, and leak. The screws never touch the spring can. Got it?
The photo I have is a bit blurred, but you can see the ring:
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Aug 12, 2001 | 07:55 PM
thanks, thats probably why I've been ripping the diaphrams, I have been putting the ring on the inside of the assembly between the diaphram. hopefully that will solve the problem.
Vader, I would like to thank you especially, you've been a great help to me with my new project.
Jim
Old Aug 13, 2001 | 01:45 AM
Bruce89TA's Avatar
Car: 89 Firebird T/A
Hey Camaroguy,
I've got half a dozen used FPR diaphrames if you need one. They're all in good shape, I bought a whole lot of them to make myself a homemade AFPR so if you need one or two, let me know.
-Bruce
Bruce Chang
ICQ #2992488
89 Firebird Trans Am
305 TPI, Procharger Supercharger, SLP Siamesed Runners, Ported Plenum, Jet Airfoil, Edelbrock TES, Hotchkis LCA's and Panhard Rod, B&M Shift Kit, March Power Pullies, Suspension Techniques Lowering Springs, Spohn Subframe connectors and driveshaft loop, Flowmaster Muffler, Accel Super Coil, Crane Hi-6 Ignition, Energy Suspension motor, tranny and torque arm bushings
Old Aug 13, 2001 | 02:54 AM
thanks for the offer but I have a holley AFPR and it comes with the internals. I'm sending it back to summit under warrenty so I'll have a brand new unit. Thanks again.
Jim
Old Aug 13, 2001 | 03:42 PM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
Your aftermarket (adjustable) regulator probably also has a thicker (about 1/8") flange so the load ring is not required, and probably won't even fit over the top.
[This message has been edited by TunedPort350 (edited August 13, 2001).]
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
Fanatic1074
Oct 2, 2015 03:47 PM
TexasFormula
Sep 30, 2015 06:36 PM
