Coldstart help!!!!!!!!! What can I do????
Old Aug 13, 2001 | 12:24 PM
JucinGTA's Avatar
Has anyone bypassed there coldstart? I know you can just plug the part on the fuel rail, but what do you do about the piece, that mounts to the runner, how do you plug that? does anyone know the size of the thread on the fuel rail side in "-an" is it like a 6? any help is appreciated!!!!
Old Aug 13, 2001 | 01:28 PM
JucinGTA's Avatar
Im assuming a coldstart explains itself, it helps the engine start when its cold by injecting more fuel correct? I unplugged it to see what it would do, and it started but it took a couple seconds longer, but it fired up, will this take longer when the enigins warm too?
Old Aug 13, 2001 | 01:32 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
The cold start injector is just that, it richens the mixture when the engine is cold. It is not controlled by the ecm, but by a thermal switch. Beyond a set temp (not sure just offhand what it is....) the injector does nothing. (I.E. warm engine.....) But, if you drive your car in the winter months... You will have a hard time getting it to start and run in the morning.
Why are you disconnecting it anyway?
Old Aug 13, 2001 | 01:34 PM
JucinGTA's Avatar
need another fuel source do you know how to plug the part off at the runner?
Old Aug 13, 2001 | 02:28 PM
Guest
Guest
Posts: n/a
Need another fuel source? Then leave the cold start alone and hook up to the fitting on the passenger side fuel rail, just take the schrader valve out first.
All disconnecting the cold start will do is make the car hard to start up.
Old Aug 13, 2001 | 03:57 PM
JucinGTA's Avatar
I need a non obvious fuel source!!!!!DAAA!!!!!
ericjon262
Mar 2, 2014 01:06 PM
GhoSSt
Apr 11, 2013 01:04 PM
327 iroc
Apr 26, 2006 09:33 AM
Wingnutt
Oct 5, 2004 08:55 PM
