Strange fuel pressure problems. Please Help.
Old Aug 13, 2001 | 09:05 PM
JETHROIROC's Avatar
I just re-installed a new Accel injector to replace the one leaky one I located, as well
as a new Holley AFPR that Jeg's sent me to replace the old leaky one. Now that
motherf$#@%r is still not holding pressure and for the life of me I can't see why not.
I even rebuilt the fuel rail this time with new o-rings and it doesn't leak a drop. When
I turn the key the pressure spikes to about 50psi and drops to 44psi after the pump stops running, and then leaks off from there in about 15 minutes like the last time. I pinch either fuel hose individually and it leaks down (even though I inspected the injector tips for leaks multiple times), but if I pinch the crap out of both at the same time it holds. What the hell is going on here? Should I, for fun, install the stock regulator and see how that pans out? With the car running, where should the pump stabilize the pressure at, or will it dip all the time? Thanks guys, this is really getting under my skin .
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley AFPR, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Ruger P95DC, hot wife, new oil filter, thick rubber floormats, no cats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Aug 14, 2001 | 07:36 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Try REALLY crimping off the return line. My guess is that the check valve in the pump is going bad..........
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
