Need help with TV cable on L98...
When I pull TV cable all the way towards the passenger compartment my shifts are terrific, only the throttle body wont't open all the way and performance suffers. Any way to have my cake and eat it too!!! Ps this is on a vette, the "vette" forum guys aren't as knowledgeable, in general, as you f-body guys are...
Car: '89 GTA
Engine: ZZ6TPI
To set the TV cable, pull it all the way back like you did, then open the throttle all the way by hand and you should hear the TV cable ratchet itself to the correct setting. If your shift points are still not not correct, then it is most likely an internal transmission problem, or a fluid level problem.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Magnaflow cat-back,
K&N open element,
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
https://www.thirdgen.org/newdesign/tech2/detent.shtml
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Z28/ZR1
Oct 23, 2015 01:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
