Accel injector clips
Old Aug 16, 2001 | 04:41 PM
IEATC5's Avatar
I have 1991 TA with a 305 TPI ... I replaced the stock fuel injectors with Accel injectors but couldnt get the clips to line up ? ... I see there are a few opinons out there ,,, I have been running the car @ 30lbs of fuel pressure and have not seen any leaks ,,, are they really needed at all with aftermarket injectors ?
Old Aug 20, 2001 | 06:29 AM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
<font face="Verdana, Arial" size="2">Originally posted by IEATC5:
</font>
Yes!!! Modify the grove on the injectors so that the clips fit, or get a *** fire extinguisher, because you'll need it.....
ZaphodB a.k.a Carl Andersson - zaphodb@faxancruisers.org
'89 Camaro IROC-Z 5.7L TPI - Mods under construction :-)
Custom ARAP Chip Under Development/180 t-stat, Edelbrock TES Headers,
SLP Airfoil, K&N Filters, Accel 8mm wires, Relocated MAT, AFPR @ 45 PSI
seiplentz
Aug 19, 2019 06:02 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
