are these good head for the money..
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
i have a set of heads available, they are aluminum l98 CNC cleaned and milled.they have a 2" intake,1.56" exhaust, and have screw studs and big springs. he says he has made 310 rwhp on his vette with them. they are 55cc chamber. my motor is a stock 5.7 for now, but heads and a cam are just around the corner. What do you think, he wants $750.00 for them. the cam i am looking at is a 211/219 .499/.525 @1.5,LSA of 112. your opinions are welcome THE SHAGGY IROC
'89 SHAGGY IROC
L98, W/C T5, all free stuff,T.E.S.,HOOKER CAT BACK,KYB,ACCEL8.8,JET fan sw. etc. 14.4@ 98.8 MPH w/t-5, can't wait for to install my 3.27 B/W.
so much to do , so little money
'89 SHAGGY IROC
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
If they are indeed CNC ported (by whom? to whose specs?) then for $750 they might be a good deal. If you're really interested, I'd find a local head porting shop and pay to have them inspected... if the seller is on the level he'd probably split the cost with you. You want to have the valves measured, know the condition of the seals and guides, how much lift they can handle, what the specs on those springs are, and if the head shop does indeed believe that the heads were CNC ported.
New L98 'vette heads with 58cc chambers, screw-in studs and 1.94"/1.50" valves.
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
you'll see if they were cnc'd by looking into the intake runner or exhaust port on stock heads there is a lot of casting flash left in there so much to the point where you cant clean it up without extensive work.IMO i would ask him who did the work and if it's local say let's take a ride over there to have them look at it,if he objects ditch him or beat him in the head for trying to beat you.(don't do this near a police station)just kidding(about the police not the beating)
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch&t-stat,tb bypass,accel supercoil,cap& rotor,hollowed maf,slp 3in. catbcak.
FOR SALE!FOR SALE!FOR SALE!FOR SALE!FOR SALE!
EVRYTHING IS FOR SALE WITH MY CAR (EXTRA ENGINE,TPI INTAKES,RUNNNERS,PLENUMS,ECM W/CHIP,new springs,aluminum driveshaft.
GETTING OUT OF THE 3RD GEN MARKET BEST OFFERS
CONSIDERED!!!!!!!!!!!
anyonne from new jersey interested??????
Well, those heads are about the same price as world products s/r torquers, and are probably better heads, especilly since they're aluminum. But the one thing that concerns me is the 55 cc chambers, those are awfuly small. I think the stock chambers are 64 cc, so it's going to raise your compression up pretty high.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
L98 TPI 350 (5.7L)
It's OK to raise compression with aluminum heads as they dissipate combustion heat much more quickly than iron. However, I'd rather have 58cc in those 'Vette heads.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley AFPR, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Ruger P95DC, hot wife, new oil filter, thick rubber floormats, no cats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
1990 IROC 350
My nifty little online program says it will raise your compression by about 1.5 points. For aluminum heads with that size valves that is a decent deal. That cam looks somewhat like the LT4 HOT cam, I've seen people make good power out of that combo. The LT4 cam is 218/228 .525/.525@1.6r 112.
[This message has been edited by rezinn (edited August 19, 2001).]
If they are relly cnc ported,than $750 is a decent price(in my opinion).As for the S/R Tourquers,you can get them fully assembeled and shipped for under $600 from www.competitionproducts.com
Shoot Shoot!!!!!
Shoot Shoot!!!!!
NinjaNife
Aug 23, 2015 11:49 AM
