what size injectors?
Old Mar 7, 2008 | 10:26 AM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
with all my mods in my sig, the cam is actually being installed right now with 1.6rr's and all the other nessasary things required in a cam swap ( springs, shims, timing chain ect..) ive been planning to put on a procharger, but funds are starting to run dry. so far this year the car pretty much has had the unibody version of a frame off restoration. and i still have a ways to go on body work. and all the other sutff that comes with it. so the question is, what size injectors would do good with this current combo? the stock ones are pretty shot. the car sat for about 5yrs. should i just replace the 19's and bump up the fp? or go BIGGER?? thanx in advance tpi guys, dave....
Old Mar 7, 2008 | 09:10 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: what size injectors?
Buy 19#/hr Ford Racing injectors AND buy an AFPR.
92projectcamaro
Jan 18, 2016 08:00 AM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
BAMiller
Sep 14, 2015 06:38 PM
