Royal Purple?
Old Mar 7, 2008 | 12:31 PM
The White Knight's Avatar
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
Royal Purple?
Using Royal Purple 10W30 Syn. oil in my Formulas Gen 1 350?
It is a 80,000km motor, sat for a while, ran 10w30 conven. in it, and not a leak or drip from it...
Id like to flush this oil out as its first oil thats been thru motor, so Id like to drain it before spring and fill it with RP.
Any things I should worry bout?
Old Mar 7, 2008 | 01:05 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
Re: Royal Purple?
if the car sat that long id dump that oil. put in another 5qt's of the conventional stuff. run the car for a while. and drain while hot. then pour in youre fresh rp. after my car sat for years. i did about 4 oil changes. before puting in synthetic. get the crap and gook out of there.
Old Mar 7, 2008 | 04:06 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Royal Purple?
I always seem to have massive leaks and oil problems when I run synthetic oil in an older, high mileage engine. If the engine is freshly rebuilt or less than 20k miles then I use Mobil 1. I'm just not too sure you'll get good results running super thin oil in an engine with wide tolerances from mileage. Now, if you run synthetic from the beginning, you'll be fine at higher mileage...
Old Mar 7, 2008 | 04:38 PM
ezstriper's Avatar
Car: 91 Z28
Engine: 6.0 LSX 88 Turbo, EFI E85
Transmission: Glide
Axle/Gears: Strange 3:73 9"
Re: Royal Purple?
the stuff is great !!! I run in my race car and boats !!!
Old Mar 7, 2008 | 09:09 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Re: Royal Purple?
I just saw today "Walmart" Carries Royal Purple , but I've only seen it with the 5w-30 for now
Old Mar 7, 2008 | 09:54 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Royal Purple?
I will have to check Wal-Mart out. The last time I was in they only had Mobile One and maybe another brand for synthetics.
Old Mar 7, 2008 | 10:27 PM
SPANX's Avatar
Car: 91 rs
Engine: 5.0
Re: Royal Purple?
You can actually mix royal purple with conventional oil if you had to, so do not worry about getting it all out even if there is build in your motor, that royal purple will flush everything out after about 1000 miles of hard driving.
Old Mar 8, 2008 | 10:34 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: Royal Purple?
If you have a small leak. It will be bigger with syn oil. The seals absorb something from the con oil, the syn takes it out, and the seals then leak.
10w-30 is 10w-30
con oil is blended 5w plus 15w = 10w (just for example). natural oil molecules are slightly different lengths. syn oil all exactly the same. some is rated 0w-50 (casterol) cold flows like 0w, hot like 50w.
Hotrodboba400
Dec 10, 2019 07:07 PM
3rd gen money
Oct 11, 2019 09:57 PM
Elephantismo
Feb 13, 2019 12:51 AM
Cleotiz
Sep 16, 2015 08:02 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
